2002 audi a4
throttle body 2002 audi a4
Can anyone tell me if oil supposed to shoot into the throttle body. Please respond with an answer. If you know, please advise on how to repair this problem. Thank you appreciate a response.
here is a pic of the throttle body and the hose that connected to the throttle and if you could tell me what is the other thing it connected to the other side of the hose.
hose
throttle body
dont know what this is
hose
throttle body
That is your air intake to the engine not an oil line. What is probably happening is your PCV is starting to fail and it is allowing oil to blow back into the intake. Replace your airfilter (it is in the square balck box) and the pcv (driver's side of the engine) and you should see an improvement. If you go to ECS Tuning and search for the part there should be a picture of what it looks like. They are pretty easy to change (at least on my 2008 2.0T it was).
There could be other issues causing this as well. I would bet your air filter is clogged with oil and dust/dirt.
rkmA4
05-25-2009 07:29 PM
nomar
11-22-2008 05:11 AM
nukauto
02-02-2008 11:02 PM
