2002 audi a4
Old Mar 28, 2014 | 01:14 AM
reck68's Avatar
Default throttle body 2002 audi a4
Can anyone tell me if oil supposed to shoot into the throttle body. Please respond with an answer. If you know, please advise on how to repair this problem. Thank you appreciate a response.
Old Mar 28, 2014 | 09:34 AM
rhodes991's Avatar
Not that I am aware of. How is the oil getting into the throttle body?
Old Mar 28, 2014 | 07:26 PM
reck68's Avatar
it's shooting out of the holes that is connected to the throttle body
Old Mar 29, 2014 | 09:29 AM
rhodes991's Avatar
As far as I know there should only be fuel and air mixing in the throttle body. Would be helpful if you could take a pic of the hose and post it.
Is your car a diesel engine?
Old Apr 15, 2014 | 04:38 PM
reck68's Avatar
here is a pic of the throttle body and the hose that connected to the throttle and if you could tell me what is the other thing it connected to the other side of the hose.
hose Name:  hose.jpg
throttle body Name:  2.jpg
Size:  7.3 KB dont know what this is
Old Apr 16, 2014 | 09:44 AM
rhodes991's Avatar
That is your air intake to the engine not an oil line. What is probably happening is your PCV is starting to fail and it is allowing oil to blow back into the intake. Replace your airfilter (it is in the square balck box) and the pcv (driver's side of the engine) and you should see an improvement. If you go to ECS Tuning and search for the part there should be a picture of what it looks like. They are pretty easy to change (at least on my 2008 2.0T it was).
There could be other issues causing this as well. I would bet your air filter is clogged with oil and dust/dirt.
Old Apr 16, 2014 | 09:17 PM
reck68's Avatar
Do you thing the Intercooler has oil in it? I will check the airfilter and pcv thanks
sports265
Jun 10, 2009 10:37 PM
rkmA4
May 25, 2009 07:29 PM
nukauto
Feb 2, 2008 11:02 PM
bullitz400
Feb 2, 2007 09:58 PM
