Sponsored by:
Sponsored by:
AC blows hot/cold/hot/cold = weird
Old 10-07-2007, 09:03 PM
M3Armand's Avatar
Default AC blows hot/cold/hot/cold = weird
So my wife's car is at it again. At 168k miles, I suppose things are due to break. So far, we have been able to fix many things ourselves (except the clutch replaced at 130k-ish miles which probably could have lasted another 30k miles). I've searched and came across nothing like this.
My wife's 2001 A4 1.8T AC blows cold / hot / cold / hot air every 20 seconds or so. It's weird. First, I thought the temp sensor at the Ac was dirty - so I vaccuumed all the lint that I saw in it. But of course, it can't be THAT easy. So the problem is still there.
Does anyone have any suggestions?
Many thanks, Armand
Old 10-07-2007, 09:10 PM
qUaTtRoA4's Avatar
Default RE: AC blows hot/cold/hot/cold = weird
sounds like a coolant flow issue, not sure tho...
one of the techs on here'll be able to help you out
Old 10-08-2007, 12:59 AM
onepoint8tee's Avatar
If there is overpressure in the AC lines/compressor from being over charged, the compressor will go into a safe mode. On/off/on/off like that. Thats what I found out when I accidently over charged mine last year.
Old 10-08-2007, 06:09 AM
david9999's Avatar
Get access to a real vagcom and check codes in the HVAC system. Check the coolant level and make sure it isn't low.
Old 10-11-2007, 10:05 PM
M3Armand's Avatar
ORIGINAL: onepoint8tee
Since we didn't charge the AC yet, would this occur if it's "low" as well? Should I try to get it charged?
Old 10-11-2007, 10:13 PM
auditech79's Avatar
You should get the pressure checked before anything, too much PAG oil in the system, too much refrigerant, not enough, bad a/c switch, and bad compressor could all cause that symptom.
You need to get it diagnosed by someone that is certified to carry out those repairs.
Old 10-17-2007, 11:08 AM
M3Armand's Avatar
tommymacdog
07-15-2015 06:00 PM
1gcrazy
07-25-2012 08:54 AM
treyg
06-12-2011 09:54 PM
Turbopeeps
08-30-2010 09:53 AM
AKCoop
01-11-2009 10:15 PM
Quick Reply: AC blows hot/cold/hot/cold = weird
