Sponsored by:
Sponsored by:
2000 audi a6 2.8 quattro
Old 11-14-2012, 11:33 AM
mathiason77's Avatar
Default 2000 audi a6 2.8 quattro
I have a 2000 audi a6 and doesn't want to start. Turns over but doesn't start. Had the same problem last winter. Suggestions?
Old 11-14-2012, 04:29 PM
MicDaddy's Avatar
Can you give a more detailed description of the problem? When you noticed it, what happens, what you have already done to try and fix it, etc....
Old 11-14-2012, 04:35 PM
ECS Tuning's Avatar
Sponsor
Fail or failing crank position sensor, coolant temp sensor, dead fuel pump, bad fuel pump relay, no spark... All could be possibilities that would cause your car not to start.
Do you have a check engine light on?
Also is your 2.8 V6 a 12 valve or a 30 valve?
Jason
Old 11-14-2012, 09:21 PM
budhani786's Avatar
Jason
the 00 is a 30v.
Second the crank position sensor and all suggested parts above. BUT to be 100% you (OP) need to scan the car for codes. without a code you will be replacing parts with a blindfold hoping your car will see the light.
also keep in mind a MIL is not required for a code to be present.
Old 11-15-2012, 12:16 AM
MicDaddy's Avatar
I concur. By far, the best investment I made was purchasing a vagcom so I can scan codes, and do the testing before I spent time (and MONEY) replacing parts.
jhensley
07-12-2015 06:42 PM
jay777
03-17-2014 11:28 AM
WeinerSchneitzel
01-27-2007 04:58 AM
WeinerSchneitzel
01-11-2007 04:47 AM
kastockton
12-12-2005 01:48 AM
Quick Reply: 2000 audi a6 2.8 quattro
