2001 4.2 exhaust questions
I just installed straight through magnaflow mufflers and it too quiet. I also noticed that right side of the exhaust flows a lot less then left side. Is that because stock resonator is clogged or something?
How much louder will it get if i cut it off? I dont want it too loud either.
Second question:
Stock exhaust looks like it has a x-pipe before resonator, is that really x-pipe or pipes just welded together for stability? If it is x-pipe should i install another x-pipe instead of a resonator?
Third question:
Where is the o2 sensor located? on cat or before? Im looking to replace them with magnaflow but they dont have housing for o2 sensors.
Thanks
Second question:
Third question:
Thanks
Second question:
Third question:
Thanks
Second question:
Third question:
Thanks
02 sensors are on the cat and 2 of them are towards the front. To replace the front it needs to be thru the engine bay I believe.
