car sputters, check engine light comes on, car dies...
Well, before cleaning your MAF the car was starting...now it doesn't.
You need to make sure you have:
- enough cranking power (take off your battery and go test it); you say when you crank it the voltage goes way down; if the battery tests good - then you have a bad voltage regulator; if the battery tests bad... well, you know...
- a good ignition module - otherwise you have no spark
- a good starter
- fuel; just as said before: fuel pressure regulator and/or pump and/or filter
I'm sure the MAF wasn't your problem, but you got good mechanical practice...
good luck
- a good starter
good luck
inkhaton
08-16-2012 03:37 PM
parlayin
02-10-2010 12:33 PM
MrTigz5254
03-07-2008 11:56 PM
