car sputters, check engine light comes on, car dies...
Old Dec 14, 2010 | 08:57 AM
whitey's Avatar
I'll clean out the MAF tonight when I get home from work and see how that goes...I'm sure there's a DIY out there somewhere.
thanks.
Old Dec 15, 2010 | 10:34 AM
whitey's Avatar
Thumbs down
cleaned MAF - updated first post.
Old Dec 15, 2010 | 03:13 PM
whitey's Avatar
no one?
Old Dec 16, 2010 | 11:55 AM
chefro's Avatar
Well, before cleaning your MAF the car was starting...now it doesn't.
You need to make sure you have:
- enough cranking power (take off your battery and go test it); you say when you crank it the voltage goes way down; if the battery tests good - then you have a bad voltage regulator; if the battery tests bad... well, you know...
- a good ignition module - otherwise you have no spark
- a good starter
- fuel; just as said before: fuel pressure regulator and/or pump and/or filter
I'm sure the MAF wasn't your problem, but you got good mechanical practice...
good luck
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
