Sponsored by:
Sponsored by:
Headlight worked...now it doesnt
Old 11-10-2007, 09:36 PM
MiniSpdRcr's Avatar
Default Headlight worked...now it doesnt
Ok...so I had my car at a shop for the timing belt changed and I was there when they were taking the lights off. When he pulled the passenger side one he said oops and I think broke a connector. So now, just the HID part of the light does not work. Everything else works fine in it.
Any ideas as to what it might be? The bulb, or the ballast?
Old 11-10-2007, 11:40 PM
Jeffla's Avatar
Default RE: Headlight worked...now it doesnt
Don't matter, its his fault so he needs to fix it.
Old 11-11-2007, 12:37 PM
dankhound's Avatar
Usually when the light doesnt work at all it is the balast. It is easy to verify this by swapping the ballast from side to side. I would be suspicious of his oops thou. He may have damage a wire or something.
Old 11-11-2007, 01:24 PM
MiniSpdRcr's Avatar
Well everything else in the light works...just not the HID part. So could the ballast still be the suspect?
Old 11-11-2007, 07:05 PM
MiniSpdRcr's Avatar
Hm and now somehow it works?? What could be causing this?
Old 11-11-2007, 07:18 PM
auditech79's Avatar
The ballast or (igniter), try swapping the bulb or ballast from the left to right side and see if it does it on the other side as well. I would just swap the bulbs from side to side which is easiest. The bulbs hardly ever go bad.
Old 11-11-2007, 08:23 PM
MiniSpdRcr's Avatar
Can you just purchase the ballast (igniter) by itself? If so, where could I find one? I did not see them on ECS tuning or I missed them.
Old 11-11-2007, 10:02 PM
auditech79's Avatar
You can get them from thedealer which is mucho expensive or just buy them from Cccccchina!
www.vvme.com the cheapest bulbs and ballast probably in the world, and they work pretty good too! Not factory of course so you might as well buy both if you wanna go that route cause they are SO cheap!
Old 11-11-2007, 11:05 PM
MiniSpdRcr's Avatar
Great thank you...as always you have saved me heh.
OMG 12.99 per ballast shoot might as well get 4 heh. You are right that site is very cheap. Even the bulbs are just 19.99 per pair for all temps.
Old 11-12-2007, 08:21 AM
MiniSpdRcr's Avatar
One more thing...the ballast is interchangable? I will not have to splice anything or will I?
sinaloaeshop
07-07-2014 09:17 PM
themikeindy
07-26-2010 10:43 PM
hawks2842
08-25-2006 08:55 PM
Quick Reply: Headlight worked...now it doesnt
