Sponsored by:
Sponsored by:
More than a boost leak? Stumped
Old 08-11-2012, 06:01 PM
2000audi27's Avatar
Default More than a boost leak? Stumped
The other day I put a stage 1 tune on my Audi a6 2.7t. I have forge splitters adjusted at about 25 clicks.
When I take off it will spike to 15psi and then I hear a Pshhh coming from under the hood(not the splitter valve noise), then it runs at 6 or 7psi. It runs great but I should be able to stay at the 15psi though. It only happens on the first "launch" though. After that I cannot get it up to 15 again, it will only stay at 7. If I turn my car off and then back on I can spike to 15 again, but just once. What do you think the problem can be?
I looked for cracked hoses and I tightened all clamps. I took the hose off the n75 to see if that was bad but it wasn't.
I'm stumped here guys, I'm new to turbos but I have done a lot of searching and couldn't find a solution or even similar problem. Any input is much appreciated.
Old 08-12-2012, 09:45 PM
ImTheDevil's Avatar
Have the computer scanned for pending codes and do a vacuum check - you may have a boost sense problem or a vacuum leak.
Old 08-12-2012, 11:25 PM
2000audi27's Avatar
I scanned it with vcds and I got a p1557 code. That's most likely a boost leak right? Or could it still be a n75 valve?
Going to do a pressure test this week and see if I can find any leaks.
Old 08-14-2012, 10:26 PM
2000audi27's Avatar
Did a pressure test and there was a long slit on my TBB. Just got a new one and im running 16psi now.
to4xxx
06-08-2012 11:56 AM
onepoint8tee
06-27-2007 04:38 PM
truckjunky87
02-08-2007 12:33 PM
fenderstrat1184
12-21-2006 02:35 AM
Quick Reply: More than a boost leak? Stumped
