Please HELP!!! Transmission problems :-(
Can someone help me figure this out? My trany is acting weird. First gear is OK, but then it could jump true the gears really quick. It could be 25-35 MPH on the speedometer and in 4th gear with RPM at 1500 mark. I was driving home from work today and it got stock in one of the gears (not sure which, instead of the gear number, there was a gear icon on the cluster display). I parked the car and pulled out my laptop out of the trunk along with VCDS. Plug it in and this is what I got:
Thursday,13,December,2012,17:12:08:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Address 02: Auto Trans Labels: 09L-927-760.lbl
Control Module Part Number: 4F1 910 156 Q HW: 09L 927 156 A
Component and/or Version: AG6 09L 4,2 MPI USA 0040
Software Coding: 0000002
Work Shop Code: WSC 02325 785 00200
VCID: 32610411AD34409
1 Fault Found:
009988 - Transmission Friction Element / Clutch E
P2704 - 000 - Apply Time Implausible
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 71437 mi
Time Indication: 0
Date: 2012.12.13
Time: 17:10:14
Freeze Frame:
RPM: 2784 /min
RPM: 2336 /min
RPM: 1760 /min
(no units): 5.0
(no units): 101.0
Temperature: 88.0°C
T.B. Angle: 28.2°
After shutting the engine of then on, it was switching true the gears but was doing this crazy **** again. Its swinging true the gears very ruffly. When I put it in sport, its feels like its functioning correctly/normally with the exception that it keeps the RPM high. When I switch the gears manually, it switching the gears with a delay and you can see the RPM Jump just like it would on manual transm. and its kind of rough. Its ben going on for the past three monts and it started with a gear being stock and that gear icon.
How do you check the ATF oil level with the VAG-COM/VCDS?
Please help me figure this thing out.
Thanks in advance.
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 71437 mi
Time Indication: 0
Date: 2012.12.13
Time: 17:10:14
Freeze Frame:
RPM: 2784 /min
RPM: 2336 /min
RPM: 1760 /min
(no units): 5.0
(no units): 101.0
Temperature: 88.0°C
T.B. Angle: 28.2°
Thanks in advance.
09l, 2006, 32610411ad34409, 42, a6, audi, clutch, friction, p2704, powered, thunk, transmission, transmissionfrictionelement, usa, vbulletin
