Flaky site to post problem but here goes
Old 11-01-2014, 12:08 AM
Daulton Ruff's Avatar
Default Flaky site to post problem but here goes
Again-one more try-
Posted problem and photo yesterday-which disappeared-Thank you-Once you sign in and post photo and forum recognizes you why would your post be eliminated?
If this disappears tomorrow I'm done and off to a site that someone will help with a problem.
2001 Quatro TT
I thought I was following the directions on this forum and I made the error of disconnecting a fuel line instead of the crank case sensor. We managed to put the bolt back in but we are not sure there is not a washer gasket both above and below the bolt. I have the one between the top of the bolt and the fuel line. Is there another?
Where is the crank case sensor? It is not next to the oil filter.
There are three electrical connections in the front above where I took the 10mm hex nut out. Which one is the crank case sensor connector?
Thank you for your time and suggestions.
Old 11-02-2014, 07:45 AM
r6forfun2008's Avatar
Fuel line has washer above and below. Crank sensor connecter is grey colored and if I remember correctly crank sensor is black colored. Located between the oil filter and transmission just slightly above the oil pan about 2 inch. Hope this helps.
Old 11-02-2014, 10:17 AM
jjt1234's Avatar
additionally........being new here myself, I made a post that disappeared also. I now copy my reply before I post it. Why? Because evidently there is some sort of "Time-Out" that occurs if your not moving around.
Nick6509
08-20-2012 11:20 PM
rehan1212
12-06-2010 04:18 PM
UllSang
02-05-2009 11:58 PM
Notahondaowner
07-18-2008 01:44 PM
TurboToughTT
03-06-2008 03:56 PM
Quick Reply: Flaky site to post problem but here goes
