O2 Sensor 17521
O2 Sensor 17521
Hey, i sure this has been discussed many times, but how many o2 sensors does the 1.8T engine have? From what I have gathered since it only has 1 bank of cylinders it has 2 sensors, 1 pre and 1 post cat. Let me know is that is incorrect. i have pulled a 17521 code which I think is the pre-cat sensor, if you could confirm or deny this I would really appreciate it. the CEL light is not on, but the code is looming. Also have any of you had good luck with universal o2 sensors or should i stick with a direct oe replacement? i have also heard it is better to replace all o2 sensors at once, but i dont know if that has any merit. Thank you very much
2 sensors, pre and post. Just make sure you get the correct sensor for your engine code. The universals work just fine, they are the same thing as the specific ones, just dont have the connector. Its a good way to save $50.
You dont have to change both, only reason i see doing both is since you are in there... but i dont usually replace whats not broken and not a hassle to replace.
If you dont have a constant cel, you probably dont have a bad o2. Better chance of a blown gasket. The turbo the manifold ones suck and blow often. Most run w/o them so check for leaks in the exhaust system
I cleared the code and it came back right away, but the CEL has not come on once. Which gasket were you referring to? Is it something I should be concerned it? The way you described it sounds like its a common failure. Thanks again Cincy.
If indeed there is a leak there is it something I should worry about? Also since the code is there but the CEL is not on, is there different levels of o2 malfunctions? At what point would this code trigger the CEL? thanks
The code has been there over a month and driven over a 1,000 miles. If must not be malfunctioning enough to trigger the cel? does the cel take in consideration different levels of malfunctions or is just working or not working?
I put on a new catted 42dd downpipe (with new gasket) about a month ago with o2 spacer on the 2nd O2 sensor, and I did an autoscan and found this :
VCDS-Lite Version: Release 1.0
Sunday, 15 July 2012, 15:07:36:0
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,55,56,76,77
Address 01: Engine Labels: 06A-906-032-AMU.LBL
Controller: 8N0 906 018 K
Component: 1.8L R4/5VT G *0003
Coding: 06710
Shop #: WSC 79415
TRUWT28N511011364 AUZ5Z0Y7303282
2 Faults Found:
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 -- 35-10 - - - Intermittent
16525 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit: Malfunction
P0141 -- 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: Redir Fail!
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 01236
No fault code found.
_______________________________________
Do you think it could be the sensor(s) or maybe a leak in the downpipe ??
also, I did a log with vag-com and Have ALOT of timing pull right around 5000rpms
Thx
Coding: 06710
Shop #: WSC 79415
2 Faults Found:
Coding: 18446
Shop #: WSC 01236
Thx
o2 sensors TT
I got a code for O2 sensors. Checked the cat converter and it was fine. Replaced the o2 sensors with some from Walker instead of the Bosch. It solved my issue. I have the 3.2 litre which has 2 pairs of sensors.
jkjersey
B7 Models
06-17-2013 09:31 AM
audiblaze
12-11-2011 02:08 AM
beholder
06-01-2010 08:00 PM
neomaxddr
04-01-2009 03:16 AM
TTsteve
05-07-2006 12:34 AM
