Crank position sensor
Old 05-09-2009, 06:35 PM
jonzo's Avatar
Default Crank position sensor
Hi I have a 1999 a4 1.8t 4 cyl, which recently had starting problems and occasionaly dies when driving. I brought to the shop and they scanned and said was the crank position sensor. Im having trouble finding where the sensor is located. If anyone could give some tips for replacing this sensor, would be much appreciated.
Old 05-10-2009, 02:22 AM
Tweaked's Avatar
EDIT: see posts below for info.
Old 05-10-2009, 02:39 AM
ghost6303's Avatar
i thought the CPS read the trigger wheel on the crank, which is about 2-3" behind the center of the 4th piston, so the sensor should be somewhere around there. the teeth on the flywheel are what the starter grabs onto.
Old 05-10-2009, 07:29 AM
jonzo's Avatar
Thanks alot! sounds like its not too extremely hard to find,
Old 05-10-2009, 09:39 AM
Tweaked's Avatar
Dude. I'm a total space cadet. You're right ghost. I have no idea why I wrote that, I was thinking of the engine speed sensor on a Porsche. That's what I get for posting at 2:30 am after a hectic week. Thanks ghost, post edited.
Old 05-10-2009, 09:49 PM
Lazer Viking's Avatar
crank position sensor is right infront of the oil cooler on the block itself
unless this is working intermittantly the car will not run at all if it goes bad
Old 05-10-2009, 11:25 PM
turbo kraut's Avatar
Tech Guru
the electrical connection is under the coolant bottle, i unhooked it, started cutting zip ties from up top layed down with the cutters and followed it to the sensor
Old 05-12-2009, 07:59 PM
jonzo's Avatar
Awesome, you all helped much! Thanks again
RoyH
12-01-2012 11:44 AM
Panzer6682
10-14-2011 06:50 PM
idice
03-23-2005 12:21 PM
idice
02-14-2005 11:22 PM
idice
01-31-2005 10:02 PM
Quick Reply: Crank position sensor
