Crank position sensor
Old May 9, 2009 | 06:35 PM
jonzo's Avatar
Default Crank position sensor
Hi I have a 1999 a4 1.8t 4 cyl, which recently had starting problems and occasionaly dies when driving. I brought to the shop and they scanned and said was the crank position sensor. Im having trouble finding where the sensor is located. If anyone could give some tips for replacing this sensor, would be much appreciated.
Old May 10, 2009 | 02:22 AM
Tweaked's Avatar
EDIT: see posts below for info.
Old May 10, 2009 | 02:39 AM
ghost6303's Avatar
i thought the CPS read the trigger wheel on the crank, which is about 2-3" behind the center of the 4th piston, so the sensor should be somewhere around there. the teeth on the flywheel are what the starter grabs onto.
Old May 10, 2009 | 07:29 AM
jonzo's Avatar
Thanks alot! sounds like its not too extremely hard to find,
Old May 10, 2009 | 09:39 AM
Tweaked's Avatar
Dude. I'm a total space cadet. You're right ghost. I have no idea why I wrote that, I was thinking of the engine speed sensor on a Porsche. That's what I get for posting at 2:30 am after a hectic week. Thanks ghost, post edited.
Old May 10, 2009 | 09:49 PM
Lazer Viking's Avatar
crank position sensor is right infront of the oil cooler on the block itself
unless this is working intermittantly the car will not run at all if it goes bad
Old May 10, 2009 | 11:25 PM
turbo kraut's Avatar
Tech Guru
the electrical connection is under the coolant bottle, i unhooked it, started cutting zip ties from up top layed down with the cutters and followed it to the sensor
Old May 12, 2009 | 07:59 PM
jonzo's Avatar
Awesome, you all helped much! Thanks again
RoyH
Dec 1, 2012 11:44 AM
Panzer6682
Oct 14, 2011 06:50 PM
idice
Mar 23, 2005 12:21 PM
idice
Feb 14, 2005 11:22 PM
idice
Jan 31, 2005 10:02 PM
