Key-less entry window trick?
Old 08-05-2010, 09:16 PM
MetalMan's Avatar
Moderator
Originally Posted by morpheous
That's good news,i can use that 99.00 towards something more useful. what other tricks can i do with my windows,sunroof,horn,lights? other than,what was posted? or is that all?
No other "tricks" can be achieved, at least without doing some really extensive stuff.
Old 08-05-2010, 09:55 PM
morpheous's Avatar
I see.....just as well,the sole purpose was to have a scan tool at my disposal,no more running to autozone for a scan if(god forbid) a CEL triggers a code,i can read it and clear it,for diagnostic purposes,anything else is just a bonus,like programming the windows n such
Old 08-06-2010, 04:35 AM
morpheous's Avatar
Just as a side note, the unlocked version of VagCom isn't essential. Us upstate NY guys do a LOT of work on these cars and so far the free version has carried us through everything, including the window coding. I'm still going to buy the full version, as I know it'll be needed sooner or later, but if you are just doing typical diagnostics, checking and clearing CELs, ABS lights, and airbag warnings and such, the freeware will do all you need and won't cost you anything other than the cable.
BTW, please fill in your location info through the User CP - it may pay
off for you or someone else in the future in trying to get an assist with a car project or problem, or with another local AFer wanting to hang out.
VAG-COM Version: Release 409.1-US
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 4B0 906 018 CH
Component: 1.8L R4/5VT G 0001
Coding: 16251
Shop #: WSC 63351
5 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16687 - Shareware Version. To Decode all DTCs
P0303 - 35-10 - Please Register/Activate - Intermittent
16517 - Shareware Version. To Decode all DTCs
P0133 - 35-10 - Please Register/Activate - Intermittent
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 35-10 - - - Intermittent
18010 - Shareware Version. To Decode all DTCs
P1602 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 8D0 927 156 DF
Component: AG5 01V 1.8l5VT USA 1010
Coding: 00002
Shop #: WSC 06435
No fault code found.
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
This is what came up when i ran the auto-scan but as you can see,this version of the software won't clear any of the DTC's says i need a activation code,i thought i could do the very basic of things,like scan for codes and clear them,if present without needing to pay the 99.00 fee
Old 08-06-2010, 09:36 AM
morpheous's Avatar
when i attempted to program the key-less window trick,within the Central Locking control module (35) a message came up after a few attempts by the software to read the Central Locking control module,it said"controller not responding"or something of that nature.
It's not the cable or anything,i have the settings,within system/devices set to com1 and set to com1 within the vag-com software also,not to mention that other controller modules read just fine. So what am i doing wrong? I'm using a mac book pro with windows 7 running on another partition,running vag-com in windows xp sp3 compatibility mode.
Old 08-06-2010, 12:57 PM
morpheous's Avatar
seems nobody knows why i can't program my windows with my usb vag-com,please someone give me feedback on whats the issue with my controller.
Old 08-06-2010, 02:13 PM
MetalMan's Avatar
Moderator
How much did you pay again?
Old 08-06-2010, 02:44 PM
morpheous's Avatar
$9.50 shipped
  #18
Old 08-07-2010, 01:26 PM
morpheous's Avatar
Could someone please help me program my 2001 Audi A4 1.8T AWM so the windows roll up and down via the keyless fob? I tried to access the module by typing 35 in the address entry but says it has no response from the controller.
<<<on knees,begging for forgiveness
  #19
Old 08-08-2010, 02:09 PM
MetalMan's Avatar
Moderator
If your central locking system works, my guess is that your cable/software combination just isn't capable of accessing the module. Might be worthwhile to find out if you can find someone near you with legit Ross-Tech cable and software to see if the module is actually accessible.
  #20
Old 08-08-2010, 04:29 PM
morpheous's Avatar
can you please tell me,which software,I'm suppose to use? and if using the software on a macbook pro via windows 7 on a dual boot partition using bootcamp,would be a issue?
I don't think so because i can run an actual scan as you saw in my prior post,i just couldn't clear any with the trial software.
1 I need to know if i am using the correct free shareware and if running the software in compatibility mode in windows 7 (windows xp sp2) isn't a issue.
A4_Jay
04-13-2014 03:42 PM
btmlinedan
12-02-2010 02:49 PM
sljone
03-05-2010 12:51 PM
goatmaster3000
03-13-2007 02:00 PM
dogskull666
12-05-2006 11:45 AM
Quick Reply: Key-less entry window trick?
