Keyless Entry Battery Replaceable?
Old 04-19-2012, 10:49 AM
joeynach's Avatar
Default Keyless Entry Battery Replaceable?
Hey Guys,
I have a 2000 Audi A4 1.8T and my Key-less Entry Remote is basically dying if not dead already. The car is 12 years old now so Im pretty sure the battery in the remote is dead and needs to be replaced. The questions is how? What battery do I need to purchase first and foremost, and also will the remote need to be re-programmed. I took the Remote apart the other day by separating the bottom half from the top (with the switchblade), and I didn't really see where the battery was and how to get at it for replacement. Any help would be great. Thanks.
Old 04-19-2012, 11:03 AM
redmond1501's Avatar
You need to pry apart the bottom half of the switchblade. The fob takes standard watch batteries available at any drugstore (look at the number on the battery).
If you need to reprogram, search on this forum for complete instructions. It's easy, something like this: Put one key in ignition and turn to ON postion. Put second key in driver's door, lock car manually, then press the unlock button.
Old 04-21-2012, 02:31 PM
joeynach's Avatar
I dont think I have two keys, just the one.
Old 04-22-2012, 01:10 AM
Sheasta's Avatar
I just did this the other day. Once you replace battery as stated above you must follow this procedure or another because there are a couple. You don't need two keys for 2/3 procedures I know of. The one I used is: While holding unlock or lock button put key in drivers door and turn the key. When all of the windows go down halfway your key fob should work again. Good luck.
Old 04-22-2012, 01:38 AM
FishEye's Avatar
honestly i'd just save the time and trouble and bring it to the dealer to have it reprogramed
Old 04-22-2012, 03:05 PM
Sheasta's Avatar
Took me 30 seconds.
Old 04-24-2012, 01:13 AM
MAY5ON's Avatar
Default Key fob
I just replaced my key like an hour ago on my Audi b5. All u have to do is find extra batteries like at a drug store as quoted before and to program I only needed my one key where I used it on the drivers door. I just turned the key to lock while pressing the lock button on the key and turned it to unlock while pressing unlock button on the key and it worked right after doing that.
Hope that helps
Old 06-19-2012, 12:56 PM
ZanzibarTT's Avatar
2001 TT I just changed the battery turned the key to the left while holding the unlock button in the driver side door. After that everything on the key worked including the trunk button. Good advice guy's! Fixed it for a 12th the cost of going to the dealership.
dpatt420
07-31-2015 12:44 AM
esoterec
02-21-2015 02:03 PM
brotzvang
08-13-2008 03:39 PM
DetroitA6
08-05-2007 12:11 PM
rybid
03-16-2005 01:33 AM
Quick Reply: Keyless Entry Battery Replaceable?
