A4 B6 cranks but won't start 01314 - Engine Control Module - 49-00 No Communications
Old 10-01-2012, 07:45 PM
bharllee's Avatar
Default A4 B6 cranks but won't start 01314 - Engine Control Module - 49-00 No Communications
Greetings,
My 2003 Audi A4 (B6) is currently not starting. The engine turns over just fine but no ignition. Just before this started happening, I accidently dangled my cell phone charger (part that goes into the phone) into the cigarette lighter socket. I smelled a mild burning electrical smell. I then tried plugging the correct end of charger into the socket but noticed it wasn’t charging my phone. I got home later, checked the cigarette lighter fuse (#33) and sure enough it was blown. I replaced it and then confirmed that my phone was now charging. However I then go to crank up the car and it won’t start which is where I am.
Below is my VAG scan from VCDS (I omitted groups that had no errors). I check measuring blocks in the 17-Instrument cluster, group 125 for CAN-Databus Communication (Powertrain). Engine is 0 which I believe means the ECM is not online at all. I took apart the ECU box and checked the two fuses which are OK. I re-seated the 4 relays as well as the actual ECU plug but same issue. Anyone have any guidance on what to check next?
VCDS-Lite Windows Based VAG/VAS Emulator Version: Release 1.1 Ross-Tech: Home
Workshop Code: 000 00000
Self-Diagnosis Log Monday, 01 October 2012, 17:43:03:21586
VIN Number: License Plate: Mileage: Repair Order:
Chassis Type: 8E - Audi A4 B6/B7 Scan:
01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 8E0 927 156 Q
Component: AG5 01V 3.0l5V USA 0912
Coding: 0001002 Shop #: WSC 63351
VCID: 3C0BE3A13F65
1 Fault Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 003 - Mechanical Failure
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04497 Shop #: WSC 06435
VCID: 2D2DDEE5F41F
3 Faults Found:
P1850 - 35-00 - -
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 35-00 - -
P1850 - 35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043 K
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
VCID: 29252AF5C0F7
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-00 - Blocked or No Voltage
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Controller: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 03200
Shop #: WSC 09222
VCID: 3217CD99ED21 AUZ6Z0B0262416
1 Fault Found:
49-00 - No Communications
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.LBL
Controller: 8E0 959 760
Component: Sitzmemory R2 F 0203
Coding: 00002 Shop #: WSC 63351
VCID: F1958295A8A7
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
00466 - Control Module for Steering Column Electronics (J527) 49-10 - No
Old 10-06-2012, 12:03 AM
redline380's Avatar
Legal Moderator
with the key in the on position, does the cel come on? i would suspect a fuse may be blown perhaps. check the ones in the ecu box before you get too excited.
pestana50
08-06-2012 12:37 AM
pestana50
06-05-2012 05:52 PM
wemmington
06-18-2007 11:56 AM
Quick Reply: A4 B6 cranks but won't start 01314 - Engine Control Module - 49-00 No Communications
