B6 window regulator DIY
My car just did this on the rear passenger side. it will go down by motor and slowly go down over bumps but it wont go up. but i can still hear the motor go when hit the up switch.
So can I just buy the kit that has the plastic pieces or the whole regulator assembly?
the parts are much cheper at http://www.genuinevwaudiparts.com/
here are the part numbers as well.
Part numbers are:
Front Driver's side(left): 8E0837461C
Front Passenger's side(right): 8E037462C
Rear Driver's Side(left): 8D0839461
Rear Passenger's Side (right): 8D0839462
Part numbers are:
My window is stuck up instead of down like everyone else's (I can start rolling it, then it gets stuck and rolls itself back up by itself), is it still likely the same regulator issue?
Also, why can't I just buy the clip by itself instead of the whole regulator?:
http://www.ecstuning.com/Search/4B0837463B/
#19
newbie
Whats up guys im new at using this... Mad props for posting the window regulator up!!! can anyone help me on my car.. Its pretty wierd the windows dnt roll down... when i lock the car the driver side door doesnt lock... and seems like everything on the driver side door doesnt work.. Any suggestions?
#20
audi a4 quattro tiptronic output propeller shaft seal leak
Hello,
i have searched for a diy on this and cannot find one.
Can you direct me to one? I have my window regulator on order.
Then the seal started leaking.
Thanks,
drbcollie
Thanks,
drbcollie
