B6 window regulator DIY
Old Nov 14, 2009 | 08:25 PM
tamirenee15's Avatar
My car just did this on the rear passenger side. it will go down by motor and slowly go down over bumps but it wont go up. but i can still hear the motor go when hit the up switch.
So can I just buy the kit that has the plastic pieces or the whole regulator assembly?
Old Nov 17, 2009 | 07:56 PM
Bump, anyone? Im tired of tape holding my window up.
Old Nov 18, 2009 | 12:27 AM
auditech79's Avatar
You need the whole regulator.
Old May 16, 2010 | 10:10 PM
PXA4's Avatar
Have a 2003 A4 Quatro, have the new regulator to replace the bad one in the rear passenger side door. Is it the same basic job on the rear door as the front? Does the inside carrier come off the same way?
TIA!
Old May 20, 2010 | 10:31 AM
ThreePointOhhh's Avatar
the parts are much cheper at http://www.genuinevwaudiparts.com/
here are the part numbers as well.
Part numbers are:
Front Driver's side(left): 8E0837461C
Front Passenger's side(right): 8E037462C
Rear Driver's Side(left): 8D0839461
Rear Passenger's Side (right): 8D0839462
Old May 20, 2010 | 11:13 AM
PXA4's Avatar
I just orderd a Bently service manual, can't figure out how to get the door apart to get the top mounting screw for the regulator out.
Any help would be greatly appreciated!
Old Jun 8, 2010 | 05:13 PM
R3N3G4D3's Avatar
My window is stuck up instead of down like everyone else's (I can start rolling it, then it gets stuck and rolls itself back up by itself), is it still likely the same regulator issue?
Also, why can't I just buy the clip by itself instead of the whole regulator?:
http://www.ecstuning.com/Search/4B0837463B/
Old Jun 8, 2010 | 05:53 PM
  #18
auditech79's Avatar
Because the entire regulator is crap, if you just replace the clips there is no guarantee the cable, or plastic wheels the cable rides on won't break a month later.
Old Jun 26, 2010 | 10:25 PM
  #19
Lil Eddie's Avatar
Cool newbie
Whats up guys im new at using this... Mad props for posting the window regulator up!!! can anyone help me on my car.. Its pretty wierd the windows dnt roll down... when i lock the car the driver side door doesnt lock... and seems like everything on the driver side door doesnt work.. Any suggestions?
Old Jul 17, 2010 | 11:52 AM
  #20
drbcollie's Avatar
Default audi a4 quattro tiptronic output propeller shaft seal leak
Hello,
i have searched for a diy on this and cannot find one.
Can you direct me to one? I have my window regulator on order.
Then the seal started leaking.
Thanks,
drbcollie
