Brake light and dashboard light beeping+engine cuts out
Old 07-15-2013, 09:03 AM
cipi888's Avatar
Default Brake light and dashboard light beeping+engine cuts out
Hi,
Sometimes when i switch on the car i get the break (!) warning light and beep. I need to switch the key on and off a few times until it disappears otherwise it wont let me start the engine. The issue is even bigger, after i manage to start up the engine i sometimes get all the lights beeping and flashing and the engine cuts out. This issues occured only when i started the car and/or after a minute or two with the engine running.
Since two days ago this problem happens in the traffic as well, i get the dahsboard lights beeping and flashing and the engine cuts out.
This issue is very random i might get it 2-3 times a day or i might not get it at all. I am not very sure, but it seems that only when its warm outside it happens. Especially when the can was sat in the sun for a couple of hours. During ther night when the temperature is a bit lower i still get the (!) brake warning but after switching on and off a couple of times it disappears and the engine doesnt cut out.
Tried topping up the break fluid and it didnt work.
Thank you very much.
Old 07-16-2013, 05:11 PM
pa4ul's Avatar
take the car to autozone and have them scan it.
jazzo
01-03-2014 05:41 AM
a6xlr8s
01-04-2013 01:32 PM
W99A428
06-24-2010 03:10 PM
707782y
12-02-2006 05:42 PM
skibum0019
10-05-2004 01:38 PM
Quick Reply: Brake light and dashboard light beeping+engine cuts out
