CVT problems - replace with manual transmission
Old 08-15-2009, 06:22 PM
mcburton's Avatar
Default CVT problems - replace with manual transmission
Hello all,
Having problems with my 04 1.8T multitronic transmission, and after reading the countless posting on CVT overhauls or replacements, I am thinking through my options. Have any of you successfully replaced a CVT with a manual transmission or know of someone that has? Is this even possible?
Alternatively, are there certain parts in these CVT transmission that once replaced make it more reliable?
Thanks,
Matt
Old 08-16-2009, 12:38 AM
auditech79's Avatar
Yes you could, but its not financially feasable for a dailly driver. Warning lights from the TCM and ECM would flash at you all the time because it wouldn't be able to see the auto trans. Fixing the CVT and selling it is your best route.
Old 08-16-2009, 12:56 PM
texasboy21's Avatar
You cant jsut sway the trannys. You will need the engine that was attached to the manual transmission too. Search around on audizine.com about this subject, its been discussed there many times.
Old 08-16-2009, 03:35 PM
mcburton's Avatar
Default CVT replacement
Thanks for the advice auditech and texasboy.
MULEPERFORMANCE
01-12-2012 09:35 PM
Blissra
B8 Models
01-15-2011 12:00 PM
pattrick02
06-24-2009 06:39 PM
bradleyk
06-20-2007 01:08 PM
Quick Reply: CVT problems - replace with manual transmission
