Help! 2003 a4 1.8T wouldn't start this morning!
Old 04-22-2014, 11:19 AM
camps924's Avatar
Default Help! 2003 a4 1.8T wouldn't start this morning!
My 2003 a4 1.8T with 92k miles wouldn't start this morning. It would turn over and then in about 5 seconds the engine would rev down and shut off. I eventually got it started by pumping the gas in those 5 seconds. It's not an imobilizer problem as I got that fixed and that light doesn't pop up. The only light that pops on is the battery light, but I don't think it's the battery since all the electronics work fine (lights, horn, radio). The car does seem a little sluggish once I got it started. Could it be a clogged fuel filter? Or fuel pump? How would I tell the difference between the 2? Anything else I should try? What else could be causing the problem? I was gonna change the fuel filter regardless as I bought the car with 80k miles and have no idea when the previous owner changed it.
Old 04-24-2014, 12:33 PM
pa4ul's Avatar
your check engine light isnt on right? Could be a really bad vaccum leak . did u ever hear any humming noise from the back of the car. That tends to happen before the filter cloggs up. Fuel pump will just shut out on its own. Though u can make sure the fuel rail is pressurized but unscrewing the black cap at the end and depress the button inside the fuel rail. Should squirt a bit of fuel out. hope this helps!
nm3210
01-06-2012 12:22 AM
Joe Mazza
12-11-2010 06:42 PM
V8Valhalla
09-09-2009 11:52 AM
converted
11-17-2007 04:26 PM
miabhai_freaked
03-27-2006 08:44 PM
Quick Reply: Help! 2003 a4 1.8T wouldn't start this morning!
