Part Out: 2.0TFSI BPG Engine KO4
Old 09-07-2014, 12:33 PM
RkyMtnA4's Avatar
Default Part Out: 2.0TFSI BPG Engine KO4
I have a bunch of parts from a longitudinal 2006 A4 2.0T Engine code BPG - Make offer on any part you need. If you see don't a certain part listed, I might have it, just ask.
~All parts have just over 100K unless otherwise noted~
Stock air filter housing box
Stock exhaust
Catalytic converter - 50K miles
ECU w/ stage 2+ GIAC tune
Short Block - Has minimal scoring on the cylinder walls- perfect candidate for a bore
Head - In good shape, carbon buildup needs cleaning - will include valve cover if needed.
Intake Manifold
Throttle body
Pistons
Rods
Injectors
A/C compressor
Alternator
Power steering pump
PCV valve
Oil pump w/ balance shafts
Oil Pump w/o balance shafts
HPFP w/ 0 miles - $300
HPFP w/ 75K miles -$200
ALL SENSORS AND WIRING WILL BE REMOVED FROM PARTS. If you need them, let me know and we will work it out.
I also have a 1st generation APR KO4 turbo that needs new seals - GPopShop will do a rebuild for $350-450. I'm asking $500 obo.
BUYER PAYS ALL SHIPPING COSTS.
If you want pictures, or better pictures, just ask.
Cheers
Old 04-01-2015, 01:12 PM
Bcbeach68's Avatar
Default Do you still have the cylinder head assy?
Do you still have the cylinder head?
QUOTE=RkyMtnA4;1479597]I have a bunch of parts from a longitudinal 2006 A4 2.0T Engine code BPG - Make offer on any part you need. If you see don't a certain part listed, I might have it, just ask.
Stock exhaust
Intake Manifold
Throttle body
Pistons
Rods
Injectors
A/C compressor
Alternator
Power steering pump
PCV valve
Cheers[/QUOTE]
Old 04-07-2015, 11:50 AM
Default HPFP, injectors, and k04 turbo
What type of HPFP's are the ones you have? are these stock injectors? also am slightly interested in the K04, was it leaking oil or any shaft play/ damage?
Old 05-30-2015, 12:29 AM
DetroitIcon's Avatar
Default Still have the head?
I'm interested in the head and the ECU. Please call Chris if you still have .
248.242.1878
Ianf1015
03-03-2015 01:25 PM
McLaren
03-17-2014 11:35 AM
audspeed
01-17-2014 09:00 PM
zygrene
08-26-2012 02:08 AM
01s42.7t
58
05-07-2012 01:23 PM
Quick Reply: Part Out: 2.0TFSI BPG Engine KO4
