1999 2.8 coolant overflow
Old 02-22-2017, 08:17 PM
SgtMajBass's Avatar
Default 1999 2.8 coolant overflow
Hi,
I have a 1999 A4 with the 2.8L V6 and 160,000 miles. I have a problem I cannot track down. The car runs and cools fine, everything is great until I shut off the engine and then the coolant rises and overflows.
I read the forums and a lot of posts recommended replacing the coolant tank and cap, so that is done and it didn't fix anything.
One of the recurring themes that I have read is that it could be a head gasket causing pressure to build up, but the weird thing is that everything is fine until the engine is shut off.
Does anyone have any ideas of what else I can check?
thanks,
Gary
Old 02-28-2017, 07:54 AM
dave944's Avatar
Make sure you have purged the coolant system of all the air. There are usually bleeder valves on the heater hoses where they pass through the firewall.
Old 03-18-2017, 06:36 AM
SgtMajBass's Avatar
Default it was air
You are correct, there was air in the system. I warmed the car up and then opened the overflow tank, with the car running, I was able to add a lot more water/antifreeze and get all the air out. I was surprised, because I have emptied the system before and never run into this. No problems since.
thanks!
Old 03-20-2017, 04:23 AM
bonnie sacer's Avatar
sorry to hear that, maybe you should replace the Water tank cover, hope it can help you.
IPStevieB
04-14-2011 05:23 PM
Chingon1988
01-29-2011 11:26 PM
gquin1
03-25-2009 11:53 PM
MeanAudiA6
04-17-2007 02:02 PM
AZ_Zoner
11-09-2006 12:36 PM
Quick Reply: 1999 2.8 coolant overflow
