96, A6, Coolant Overflow
Old Nov 9, 2006 | 12:36 PM
AZ_Zoner's Avatar
Default 96, A6, Coolant Overflow
Recently I had a small reservoir leak and replaced it. Just a small amount when it was really hot (I live in Phoenix). While doing this I though I’d change the coolant. My problem now is that it heats up and over flows. I can’t go over 4 miles with out this happening. But the temp gauge reads fine, a little higher than what it use to but not on the high end of the gauge. I have tried topping off the fluid several times and letting it warm up slightly and then cool back down. I’ve run the heater on full. I think there is air still in the system but just can’t get it out.
Any ideas on what else it may be or a trick to get the air out? I have had other European cars that have bleed screws on the top of the block. I’ve also heard talk of removing a heater hose but I have not been able to find where they go through the firewall.
Any help would be appreciated.
Craig
AudiTeen
Jan 13, 2013 09:51 AM
IPStevieB
Apr 14, 2011 05:23 PM
Chingon1988
Jan 29, 2011 11:26 PM
gquin1
Mar 25, 2009 11:53 PM
MeanAudiA6
Apr 17, 2007 02:02 PM
