Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Dash buttons issue on a 2001 TT
Old 01-25-2015, 10:11 PM
TTismagic's Avatar
Default Dash buttons issue on a 2001 TT
I did some search, but still I don't find a solution.
The buttons on the dash (flasher, ESP, heated seats); just go inside the dash if pressed firmly.
I had to remove the stereo and cut myself, trying to reposition them. Problem is....they fall in again.
From what I read, there is a plastic sliding plate, parallel to the stereo cage, that slide out, so you can access the buttons; and there should be a sort of mechanism that plug behind each button to keep them in position.
I do not see that plastic tab, that should go behind each button. They are just stliding in the dash hole and clip trough the side clips that the buttons have; there is nothing behind them.
Am I missing something, or the retainer that was supposed to be there, was removed/broken by the previous user?
I can be gentle, but it may happen that I push with too much strength and loose the buttons again; so I am looking for a definitive solution.
I am surprised at how Audi engineered that part of the dash...Germans have big hands
emh87
02-03-2015 09:50 AM
jlnaumann81
05-09-2013 02:51 PM
boomerw
01-13-2013 04:51 PM
hangnaroundct
08-03-2012 03:11 PM
liqu1d
06-13-2008 11:05 PM
Quick Reply: Dash buttons issue on a 2001 TT
