check engine code P1136 and P1138 on 01 S4
Old 09-15-2006, 11:45 PM
duglas's Avatar
Default check engine code P1136 and P1138 on 01 S4
I have a 01.5 S4 that keeps getting the same codes..
P1136 and P1138
It means Long Term Fuel Trim Add.Fuel,Bank2 System too Lean and Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
so I know now that is is not a o2 sensor.. I am guessing a vacuum leak from doing a search, anyone know the common places to check for vacuum leaks or anyone have any idea what is causing the code????
thanks..
Old 09-16-2006, 01:57 PM
Default RE: check engine code P1136 and P1138 on 01 S4
yep ill go for the vacuum/air leak check the one under the intake manifold approx 1/2" in diameter and any other pipes
Old 09-21-2006, 12:03 AM
duglas's Avatar
The leak was the 1/2 inch hose way in the back connected to the air intake... it was coming from the firewall... plugged it in and almost 100 miles and no code......
grease
08-16-2014 05:45 PM
ChadAudiA6
01-16-2010 08:44 PM
milo55041
05-30-2009 12:53 PM
plblevins
02-13-2008 10:03 PM
plblevins
02-13-2008 12:12 PM
Quick Reply: check engine code P1136 and P1138 on 01 S4
