check engine code P1136 and P1138 on 01 S4
Old Sep 15, 2006 | 11:45 PM
duglas's Avatar
Default check engine code P1136 and P1138 on 01 S4
I have a 01.5 S4 that keeps getting the same codes..
P1136 and P1138
It means Long Term Fuel Trim Add.Fuel,Bank2 System too Lean and Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
so I know now that is is not a o2 sensor.. I am guessing a vacuum leak from doing a search, anyone know the common places to check for vacuum leaks or anyone have any idea what is causing the code????
thanks..
Old Sep 16, 2006 | 01:57 PM
techbod's Avatar
Default RE: check engine code P1136 and P1138 on 01 S4
yep ill go for the vacuum/air leak check the one under the intake manifold approx 1/2" in diameter and any other pipes
Old Sep 21, 2006 | 12:03 AM
duglas's Avatar
The leak was the 1/2 inch hose way in the back connected to the air intake... it was coming from the firewall... plugged it in and almost 100 miles and no code......
grease
Aug 16, 2014 05:45 PM
ChadAudiA6
Jan 16, 2010 08:44 PM
milo55041
May 30, 2009 12:53 PM
plblevins
Feb 13, 2008 10:03 PM
plblevins
Feb 13, 2008 12:12 PM
