help with vacuum leak?
Old Aug 3, 2009 | 10:50 PM
  #21
Tweaked's Avatar
Originally Posted by neoneddy
I had a similar issue, when ever I got into the boost much at all it sputtered, misfired-etc.
Turned out to be a coil pack, replaced, ran fine afterward, just something to think about.
The odd thing was it ran fun, but when I added the APR chip it started doing it.
Holy necrobump Batman!
Old May 15, 2014 | 04:08 PM
  #22
cowabungaman's Avatar
Default would any of this information pertain to my problem?
I checked my vacuum at the intake manifold and it reads steady at 19-20in/Hg... However, when dropping into first gear the RPMs jump from 800 to 1200 before settling every time I come to a stop. I receive the 1136 engine code for Long term fuel trim, add fuel bank 1. System to lean code. The MAF sensor has been replaced and next I will replace the O2 sensors, unless anyone can advise otherwise. Any advice is much appreciated. Thank you.
Old Apr 15, 2015 | 03:35 PM
  #23
motomatt77's Avatar
I know this is an old thread but was this issue ever fixed. I am having the same symptoms on my 08 Audi A3 3.2 Quattro. Cleaned the MAF and if went away for a while but the codes come back up eventually. When I clear them them I get a hard start and it runs terrible for about 5 minutes.
Old May 2, 2017 | 05:25 AM
  #24
Michael Haley's Avatar
Default Please help
I have a 1999 Audi a4 1.8 turbo a couple things wrong someone already took off egr thing on back and put plate there is no other way for valve cover to breath its getting to hot and help also what vaccum lines go to the turbo any pics please or if someone could call me 865-896-8954 thanks
Dizzle
Jul 20, 2010 10:39 PM
tdoyle
Aug 24, 2009 11:30 AM
x1n54n3x
May 8, 2009 04:40 PM
shkenned
Sep 28, 2008 06:50 PM
themysteryman83
Apr 8, 2008 12:40 PM
