Correct Sirius Part# A4
Old Sep 4, 2008 | 08:00 PM
TinMan.KC's Avatar
Default Correct Sirius Part# A4
I have a newly purchased '08 A4 cab, and am looking for the Sirius adapter to enable satellite radio.. Dealer tells me correct part number is
8E0 035 593 N.. Of course, I find plenty of SIRIUS RECEIVERs on the internet used.. major part number is the same 8E0 035 593, but each seems to have a different suffix letter such as D (listed as Audi), L (listed as VW-Audi). Is there really any difference between the units that esentualy have the same part number (except for the suffix letter)?
For an '08, is 2006-2008 the same chassis (B7?)
TIA
TinMan.
Old Sep 12, 2008 | 01:26 AM
bluefox's Avatar
I'm going through the same pain right now. I think i'm going with a L, because that is number the dealer gave me, and the L has one plug in the back which is what my 08 has too. I think L is the newer version with one plug but still can use RNS and TPM. The D is for cars with Navigation or tire monitor system but has two plugs, so you would need an adapter if you have one wire too. Not sure what N is for. The most I found out is some units will have either two plugs or one plug, and you may or maynot need an adapter to put the one wire into the two plug module. It all depends if you have RNS and/or TPM. Tear your trunk apart to see if you have one or two plugs. That be a good start. (One or two plugs, meaning the color ones, green/brown). I don't know, I'm still working on it myself. Hope this helps.
8E0 035 593/8E0 057 593 Sirius without RNS-E and without tire pressure monitoring system
8E0 035 593 A/8E0 057 593 A XM without RNS-E and without tire pressure monitoring system
8E0 035 593 D/8E0 057 593 D Sirius for RNS-E and/or with tire pressure monitoring system, works with Concert/Symphony as well
8E0 035 593 E/8E0 057 593 E XM for RNS-E and/or with tire pressure monitoring system, works with Concert/Symphony as well
Old Sep 12, 2008 | 06:25 AM
bluefox's Avatar
I found this on another site from someone who knows what they are doing.
Audi SAT radio - part numbers
SAT RADIO receivers: North America only
8E0 035 593 F/8E0 057 593 F Sirius,
8E0 035 593 H/8E0 057 593 H Sirius, single FAKRA antenna connector, needs splitter to work in older cars
8E0 035 593 L/8E0 057 593 L Sirius 2008, single FAKRA antenna connector, needs splitter to work in older cars
8E0 035 593 G XM, 2007
8E0 035 593 N/8E0 057 593 N Sirius, 2008.5, single FAKRA antenna connector, needs splitter to work in older cars
Audi switched to single FAKRA SAT connections beginning with the VIN shown below:
A3: WAU..8P..7A105278
A4: WAU..8E..7A126439
RS4: WAU..8E..7N904437
A4 Cabrio: WAU..8H..7K022076
S4 Cabrio: WAU..8H..7K900972
TT: TRU..8J..81000001
bootsdowd
Sep 10, 2009 12:11 PM
fenderltd
Aug 31, 2008 05:27 PM
Capthowdy
Feb 14, 2007 12:46 PM
Jerome10
Sep 9, 2006 07:58 PM
