HELP!!!! Check Engine Light????
Old Jul 28, 2005 | 06:01 PM
4dot's Avatar
Default HELP!!!! Check Engine Light????
i have only had my car for a little over 4 months, or 4000 miles and i took it to get an oil change right after i bought it. time was comming close again so i went in for a routine oil change. all day and first part of the next, everything was ok. the latter part of the day the CHECK ENGINE light came on (regular driving). i took it back and they said they checked to make sure everything was connected back together and turned the check engine light off. exactly 1 1/2 day later it pops back on!!!!!
any suggestions???????????
Old Aug 12, 2005 | 01:23 AM
bdartt's Avatar
Default RE: HELP!!!! Check Engine Light????
Have you had someone hook up the on-board computer to a diagnostic machine (usually free)? They should be able to tell you EXACTLY why it's on...
This happened on my 2001 A6 2.7T two weeks after I bought it... turned out to be a bad coolent temperature sensor that's used during startup to determine the air/gas mixture to optimize feul economy... i immediately thought to myself... who cares? Oh well... if your car was recently bought, it's probably a just a bad sensor (there are a lot of them)...
Old Aug 12, 2005 | 02:12 AM
KÖNIG A6's Avatar
ORIGINAL: bdartt
sounds right, and oil change every eight thousand miles is i think whats suggested, correct me if im wrong, just trying to help you save 50-60 bucks
Old Aug 12, 2005 | 09:31 AM
4dot's Avatar
thanx guys i had them look at it was the vaccum hoses (one of them split). 10$ and a heart attack later everything is fine. (whew!)
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
