Flickering Headlight
Old Feb 25, 2003 | 10:33 AM
koolkef's Avatar
Default Flickering Headlight
Hi all again,</P>
Names Kevin. Just aquired a 1 yr old A6 (2002 model). I notice sometimes that when I switch my headlight on, my left headlight flickers then no light, but when I switch it off and on again, It's ok. Could it be the bulb?</P>
Thank you.</P>
</P>
</P>
Old Feb 27, 2004 | 07:53 PM
BiTurboMan's Avatar
Xenons or Halogen???</P>
Either case, I would check the bulb wiring / relays. If it is Xenons, check for water or moisture in or around the ballasts. Also, look for the connections on the bulb... Perhaps, the bulb might be bad..?</P>
gahndai
Feb 12, 2013 09:40 PM
spacer
Sep 16, 2011 07:50 AM
carli217
May 15, 2011 05:27 PM
ViPa
Sep 23, 2009 09:13 PM
scythe1969
Jun 24, 2008 02:07 AM
