'99 2.8: coolant temperature sensor G62
Old Oct 21, 2007 | 03:15 PM
jreddy's Avatar
Default '99 2.8: coolant temperature sensor G62
Hello,
Has anyone out there replaced the G62 sensor on a '99- 2.8? I have the part, a green plastic, and brass device with four slenderpins, but Icannot locate the part under the hood. Where should I be looking?
Cheers,
Jay
Old Oct 21, 2007 | 07:03 PM
kairo77's Avatar
Default RE: '99 2.8: coolant temperature sensor G62
Behind the engine on the passenger's side, remove the intake hose and look straight down behind the motor and you should see it facing straight upwards towards you.
To change it pull the plastic clip out and pull up on the sensor, you will lose some coolant.
Just make sure not to take off the coolant resivior cap or you will loose most of your coolant.
Make sure u have The right one. the Have 1 with round plug in. And one with square one.
Good look.
kairo
williagw
Feb 13, 2015 01:58 PM
DanaB6
Apr 22, 2012 02:48 PM
chris36
Feb 28, 2011 03:04 AM
maxdamage
Nov 15, 2010 04:47 PM
warmachine000
Apr 14, 2009 11:29 AM
