Glove Box Broke at Hinge
Old Nov 1, 2007 | 05:28 PM
93Akkord's Avatar
Default Glove Box Broke at Hinge
The right hinge to be exact. I wanted to know if this was covered under the CPO warranty. I called audi but the guy was 75% sure it wasn't. But it was still unsure. And I've seen a couple of posts here saying that it is covered under warranty...but they dont specify if it the orginal or CPO warranty.
Now I hear that it is around 400 to fix. I'm just trying to way out my options because I can't take my car in until next week, when I get my oil changed.
Old Nov 1, 2007 | 05:40 PM
hiwords's Avatar
Default RE: Glove Box Broke at Hinge
i doubt sumthing like that is covered. i would super glue it back on if u can or see if u can sumhow make sumthing for now
Old Nov 1, 2007 | 09:16 PM
EVOLA4's Avatar
mine did the exact same thing on my b6 and they said it wasn't covered. they told me it was 900 bucks for a new glovebox.
Old Nov 1, 2007 | 09:35 PM
auditech79's Avatar
Yeah B6 glove box's always break on the right hinge, you can just replace the door yourself if you want.
Pull the 10 8mm bolts out and drop out the glove box, flip it over and bang out the pins, seperate the door from the box and replace it. Its really easy to do and it will save you around $200-400 in labor.
Old Nov 1, 2007 | 09:40 PM
96A4Owner's Avatar
The hinge on my a4 broke, it sucks. But whatever, at least you can't see it.
Old Nov 1, 2007 | 09:47 PM
93Akkord's Avatar
ORIGINAL: auditech79
how much are the doors. where can I get them? seems easy enough?
Old Nov 1, 2007 | 09:50 PM
auditech79's Avatar
It depends on what color and texture the door is made of, give you dealer your VIN number and they will look up the price for you, it also comes with new pins.
I would ball park it at around $100-$200
Old Nov 1, 2007 | 11:44 PM
Kyle09's Avatar
exact same thing happened on my b6, thanks for the info tech!
Old Nov 2, 2007 | 10:32 AM
VitaminB6's Avatar
Don't know what "CPO" is, but dealer replaced mine on factory warranty, no problem and no questions asked. They even had a door in stock telling me that this is a common problem.
Old Nov 2, 2007 | 01:01 PM
auditech79's Avatar
ORIGINAL: VitaminB6
CPO means Certified Pre Owned, its not covered under CPO warranty.
sned2
Jan 26, 2016 01:58 PM
boilerbacker31
B7 Models
May 24, 2010 03:34 PM
breezy
B7 Models
Feb 17, 2010 10:13 PM
2wdBlazer
Feb 23, 2008 12:00 PM
