Power Steering Flush
Old Nov 28, 2007 | 09:43 PM
catdog's Avatar
Default Power Steering Flush
I bought the car about 6 weeks ago with 89,000 miles. The PS pump was replaced about 3 months before I bought the car. The car was rarely driven the last few months by the PO.
A few days after I bought the car the PS starting moaning and groaning loud. My mechanic sucked the PS fluid out and refilled and that fixed it for about a month. It's started again. Before I go further, I'm thinking of flushing it again. Thinking there's still some crap in the fluid.
I see 2 methods for flushing, one where you remove the resevoir and flush (doesn't seem much room on my car to get the resevoir out on my car) and one where you disconnect the hose at the radiator. Which method is best? Is either waybetter than just sucking out the fluid from the resevoir several times and running the engine after each top off?
Old Nov 28, 2007 | 09:46 PM
auditech79's Avatar
Default RE: Power Steering Flush
You NEVER need to flush the PS fluid on an audi, its mineral oil, meaning it will evaporate over time. So it moaning just means its low on fluid. What you need to do is remove the cap top it off, then with the engine running turn the wheel lock to lock several times over to aerate the fluid. You should see lots of bubbles, when the bubbles stop then you can put the cap back on.
Old Nov 28, 2007 | 09:51 PM
catdog's Avatar
The fluid level is a little over the top mark.
Old Nov 28, 2007 | 11:16 PM
auditech79's Avatar
If its still moaning do what i just said and aerate it, if it still happens after doing that for a long time then you need a new PS pump.
Old Nov 29, 2007 | 08:40 AM
catdog's Avatar
One thing I forgot to mention is that it doesn't do it all the time, but most of the time. While driving the the car, it can come and go. Because of this, I was thinking there was some debris left from the PS pump replacement a few months ago.
The fluid level has never been low.
I'll try the aerating thing now.
Old Nov 29, 2007 | 09:21 AM
maxims45's Avatar
If there is a leakage somewhere - pipes, pump itself - it starts getting air into the liquid, the air is the reason of howling. It disappears while driving (does the same as auditech79 said), but returns back after being parked for some time.
You have to inspect to whole system for leaks and potentially replace the pump ($200 for the new one or $40 for repair kit).
Old Nov 29, 2007 | 09:54 AM
catdog's Avatar
I just checked my records the pump was replaced a year ago.
I aerated turning the wheel back and forth with the top off for about 10 minutes. The froth is still there. I let the car sit while the bubbles cleared & after a short drive the noise and bubbles come back.
How long should I try aereating before I take it to a mechanic to inspect the whole system?
The fluid is brown in color and looks like there's air in it.
You know a month ago my mechanic sucked the fluid out a few times and poured new fluid in. The fluid was clear, looked like mineral oil. This cleared the problem for awhile.
Old Nov 29, 2007 | 10:16 AM
maxims45's Avatar
hey! The fuild should be clear and look like a mineral oil. NOT BROWN!
it is recommended to lift up the front (so wheels may move freely) while aerating
Old Nov 29, 2007 | 10:23 AM
catdog's Avatar
How long should I need to aereate? 10 minutes didn't do it.
Does driving harm the system with air in it? If I can't get the air out, it will probably be next week before I can get it to my wrench.
Old Nov 29, 2007 | 10:31 AM
maxims45's Avatar
As I know (guys please correct me), driving with the air in the pump (completely no liquid) will break the pump. I was driving for 3-4 weeks with this sound, periodically adding the liquid.
