Power Steering Flush
Old Nov 29, 2007 | 06:40 PM
  #21
paaudia6's Avatar
Member
Default RE: Power Steering Flush
auditech can i get it from a VW dealer its closer to my house if yes what should i ask for?
Old Nov 29, 2007 | 11:17 PM
  #22
catdog's Avatar
That's good, Febi is 5 bucks cheaper.
Old Dec 1, 2007 | 03:53 PM
  #23
dankhound's Avatar
You may have a hose that is coming apart internally causing the scren in the reservoir to keep getting plugged. Or as you said, debris from the bad pump still in the system. I would try removing the reservoir and cleaning the screens in the bottom with some brake clean.
Old Dec 1, 2007 | 09:15 PM
  #24
catdog's Avatar
What I can see of the screen from lookng in looks clean.
I flusheda liter and a half of Febi through the system sucking it out with a turkey baster. Should I mention that to my wife?
The fluid is a good clear green color. After about a half hour of bleeding with the front wheels off the ground, I'm still getting air in the system. I'm thinking there's a leak. There's no drips under the car.
Is there a power steering stop leak additive that is safe for our cars?
Old Dec 1, 2007 | 09:25 PM
  #25
dankhound's Avatar
I think theres another finer screen under that one with the large holes. On the 3.0l there is also a restrictor fitting on the hose that is on the rearward side of the reservoir. Sometimes they get clogged. It can be identifyed by twocrimp clamps on the outside of the hose near the reservoir. You can cut those clamps off and pull the restrictor out with some plyars. Also if you have a leak between the reservoir and the pump you may be sucking air into the system. You wont see signs of major leaking but rather small about of ps fluid caked on the lines.
Old Dec 1, 2007 | 09:43 PM
  #26
Figgy1682's Avatar
i was wondering to if i could go to the vw dealership and get there ps fluid for my car if i need it. the closes audi dealer ship to me is 100 miles north and 93 miles south but vw is 13 miles down the road.
Old Dec 1, 2007 | 10:21 PM
  #27
catdog's Avatar
I think you've nailed it. There is some fluid on the 2 lines coming from the bottom of the resevoir. Mostly the larger front line. Like it's weeping.
I don't know if I'm up to removing the stuff around it to be able to pull the resevoir out. I've read the tech article but it looks like I have more componets around the resevoir than described in the article.
Old Dec 1, 2007 | 10:28 PM
  #28
dankhound's Avatar
Same stuff. The bottle will probably even have the audi logo on it among other. What the hells a skoda.
If you take all those connectors off that plastic bracket you will get a better look at those lines. You can even take the plastic part thats connected to the metal bracket off. Ive never removed anything else to get the reservoir off.
Old Dec 2, 2007 | 02:00 PM
  #29
catdog's Avatar
Well, I think if done all I can do unless there's some other suggestions.
Got the resevoir out. Screens are clean, cut off enough of the hoses to put new hose clamps. Still getting tiny bubbles. Just like before.
May be time for the mechanic. Must be a small leak somewhere. I'm going to try a new thread to see if anyone knows of a stop leak for our cars.
I'll let you know the outcome. Thanks
Old Dec 2, 2007 | 02:14 PM
  #30
maxims45's Avatar
Member
IMHO do not use any STOP leak stuff!!! It fills small holes as sealer INCLUDING regular/needed holes.
What I'd recommend to do (if there are no drops around the tank) - remove the engine cover, locate you pump and carefully look around its body. There are several potential places: 1. the pump consists of two halfs - look the place they are connected. 2. two pipes (in/out) 3. staffing-box, glad on its shaft
