will stock spark plugs effect chipped engine
Old Jan 29, 2008 | 08:47 PM
austindgarner's Avatar
Default will stock spark plugs effect chipped engine
if i run oem spark plugs after getting my car chipped, will it effect the performance of the car. If so, what plugs are recommended?
Old Jan 29, 2008 | 09:12 PM
Rhinop21's Avatar
Default RE: will stock spark plugs effect chipped engine
Yea you might want to get some ngk bkr6e's and gap them to .020. With out the new gap you will likely ruin the coilpacks.
Old Jan 29, 2008 | 10:08 PM
chaos92287's Avatar
its .028 not .020
and yeah you wana run a colder plug with a chip
Old Jan 29, 2008 | 10:14 PM
cincyTT's Avatar
I'm make believe
.028 like above. There isnt really a need to run a colder plug unless you are pushing the stock turbo. I have ran stock heat range for over a year with 20psi.
Old Jan 29, 2008 | 11:34 PM
chaos92287's Avatar
what would you consider pushing the stock turbo?
Old Jan 31, 2008 | 01:13 PM
cincyTT's Avatar
I'm make believe
The people running them to 25psi, w/m inj, and every bolt on. Chip and exhuast is fine for stock heat range.
Old Jan 31, 2008 | 02:19 PM
brrman's Avatar
A regapped stock plug is fine for a chipped car.
triplerr
Nov 14, 2012 05:10 PM
Pbcrazy
Sep 5, 2012 06:06 AM
Nevalite
Apr 7, 2010 06:50 PM
mrvuml
Oct 6, 2007 01:00 PM
bihoang
Feb 21, 2007 05:04 PM
