Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
a4 map light swapped to LED - blowing fuse
Old Apr 5, 2008 | 11:55 PM
EOD5's Avatar
Default a4 map light swapped to LED - blowing fuse
hey guys, i have a 98 a4 and i just converted my interior to LEDs...every light i bought works fine
except the map lights (the two front lights you can push the button to turn on, not the center dome light)
i replaced the stock ones (12v) with the new ones which are 4 LEDs but still a 12v bulb
every time i put it in and turn it on, it blows the interior light's 10a mini-fuse
anyone have any idea here?
Old Apr 10, 2008 | 11:32 AM
EOD5's Avatar
Default RE: a4 map light swapped to LED - blowing fuse
bump?
Old May 6, 2008 | 11:01 PM
dmfan016's Avatar
do you have resistors in the 4 LED circuit? otherwise thats probably blowing your fuse you need a resistor for each LED
Old May 7, 2008 | 12:11 AM
EOD5's Avatar
i dontknow....should i have added them? or should they have been built into the bulb?
Old May 8, 2008 | 01:47 AM
dmfan016's Avatar
if you just bought the LED's by themselves they wouldn't have come with resistors but since LED's require different voltage (even tho you bought ones rated for 12 v) you need the resistors to prevent situations like that. don't worry tho resistors are cheap and can be found at any radio shack, explain to them the type of LED's your installing and they will provide you with the proper resistors
Old May 15, 2008 | 01:16 AM
dmfan016's Avatar
any progress with it yet?
Old May 15, 2008 | 01:32 PM
EOD5's Avatar
hey thanks for the info, i havent had time to check this out yet...maybe over the weekend
ondansetron
Feb 6, 2011 06:39 PM
zooyork182
Feb 5, 2011 10:31 PM
jcrawford
Dec 17, 2009 09:54 PM
varian72
Aug 15, 2009 10:25 AM
rayhalks
Sep 19, 2007 12:39 PM
