A6 2.7T Air conditioning blows colder on passenger side
Old Apr 24, 2008 | 05:32 AM
domenicostorino's Avatar
Default A6 2.7T Air conditioning blows colder on passenger side
Hello I jus bought my 2.7t... The air conditioning works ok but for some reason the passenger side blows a lot colder no matter what!(setting both sides at the same temp level)... Also the "Auto" button seems to set the fan speed/temp always exactly the same even if its 65 degrees at night or 96 degrees during daytime...sothere isnt really any "auto" function working here...Any suggestion?
Old Apr 27, 2008 | 04:30 PM
AudiTech616's Avatar
Default RE: A6 2.7T Air conditioning blows colder on passenger side
Your low on freongonna need to recharge your a/c system.
Old Oct 27, 2008 | 12:10 AM
its been like that for over a year... 100% cold on passenger side and around 70% cold on driver side.. although the temperature is set the same on each side...
Old Nov 9, 2009 | 08:51 PM
well its been a long time since I posted this and I just got an 02 B6 that has the exact same problem... any suggestions?
Old Sep 23, 2010 | 09:46 PM
ppgoal's Avatar
Set the passenger side temperature 30% warmer than the driver setting. This is a well-known Teutonic ploy to make the passenger cold, assuming she is a woman who will want to snuggle for warmth when you get to the final destination. If it's your buddy, you are SOL.
Old Nov 1, 2010 | 12:39 PM
FingerLakes's Avatar
Maybe your heater duovalve is sticking on the left side...low refridge pressure can also make the left side run warmer... or maybe that's the right side.
CarlosMIA
Nov 19, 2010 07:05 PM
vtraudt
Oct 25, 2010 02:46 PM
mr_indomitable
Apr 23, 2009 11:06 PM
tim7902
Sep 10, 2006 01:30 PM
