Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Suspension problem
Old 10-28-2014, 02:58 PM
Mickwal's Avatar
Default Suspension problem
My Audi A6 allroad 2004 model is bottoming out on the near side but only wen level 2 or lower is it my air bag or sensor as it doesn't always happen
Old 11-18-2014, 09:07 AM
sjames's Avatar
Default hi
I have a 2004 audi a8L my suspension setting will not come up on my computer screen. is there a way to reset the computer. is this a common problem? it is at the very bottom of the suspension and bottoms out. cant drive it.
Old 11-27-2014, 10:10 AM
allenst's Avatar
Default had same issues. my boot strap solution
if u r under warranty take to dealer.
if you are big on budget replace struts, compressor, maybe valve block, maybe some other hoses. $10,000 here in Canada
OR.
1- put car in 'jack mode' from MMI.
2- safely jack listing tire and remove tire.
3- visually inspect strut rubber bladder. 90% of bladder failure happen at bottom seal.
now try to determine if you have a tear or hole.
take a jack and lightly lift the suspension to simulate the car being on ground at all 4 points.
grab a bottle of 50/50 soap and water.
take care out of jack mode and try to lift/or pressurize the air shocks.
spray the shock really well all over especially underneath.
if you see bubbles then you got punctures or leaks.
now you decide to replace or repair.
lots out here on how to do that.
Old 12-22-2016, 04:54 PM
Jamesorr's Avatar
Having the same issue... anybody ever figure this out?
macpyro2
05-12-2009 07:57 PM
zarko9
07-09-2008 07:05 AM
ARIaudiS4
04-20-2008 09:01 PM
andrew.bator
02-05-2008 10:53 AM
305audi
05-22-2006 07:54 PM
Quick Reply: Suspension problem
