problem with suspension help!!!
Old Feb 3, 2008 | 09:06 PM
andrew.bator's Avatar
Default problem with suspension help!!!
Couple weeks ago I installed pss9 suspension with new mounts and bearings. Today I noticed that the gap between the top of strut and the base is bigger and on the passenger side the gap is so big that it hit the hood, what could i have done wrong, or missed during the instalation.
Thanks Andrew
[IMG]local://upfiles/33197/EC19BA8A63F04E1B93C98E7C706E07E1.jpg[/IMG]
Old Feb 3, 2008 | 09:51 PM
XCLR8TT's Avatar
Default RE: problem with suspension help!!!
Did you replace the bushing (#5 below) along with the bearing (#6)?
Old Feb 3, 2008 | 10:01 PM
Bushing and items 1, 4, 5, 6 were all new #2 I reused and #7 there was a different one in the pss9 setup.
Old Feb 3, 2008 | 10:10 PM
XCLR8TT's Avatar
Did get the strut seated all the way into the seat on #20 and tighten #4 before putting back up into the tower?
Old Feb 3, 2008 | 10:34 PM
The bottom of strut was seated properly and everything was tightned to factory specs.
Old Feb 3, 2008 | 11:36 PM
XCLR8TT's Avatar
You need to disassemble that side again. It looks like something slipped, most likely the bushing.
Old Feb 4, 2008 | 07:11 PM
gTT's Avatar
gTT
look at mine from the following page. (mine suspension are still stock)
https://www.audiforums.com/m_738381/tm.htm
Old Feb 4, 2008 | 11:09 PM
Could #5 in this diagram be the problem?
Its listed as bearing bracket / suspension strut mounting / F 8N-X-006 001>>*
right front /
[IMG]local://upfiles/33197/FB30758BFEA6449FABBE91E65488101F.jpg[/IMG]
Old Feb 4, 2008 | 11:33 PM
Old Feb 5, 2008 | 10:53 AM
INNI's Avatar
Default I just did PSS9 as well, but mine are fine.
Thinking back to when I was seating the strut, I don't recall ever being able to push up far enough to make #2 extend that far. You are probably missing something inside the strut tower, or #5 is bad.
Mickwal
Dec 22, 2016 04:54 PM
macpyro2
May 12, 2009 07:57 PM
zarko9
Jul 9, 2008 07:05 AM
ARIaudiS4
Apr 20, 2008 09:01 PM
305audi
May 22, 2006 07:54 PM
