Help-CEL Problem Codes
Old Oct 10, 2008 | 12:53 PM
blkb5a4's Avatar
Default Help-CEL Problem Codes
Alright well I just got my car back from the dealer getting work done and after driving it around for about 45mins the CEL came on so I stopped by an Autozone and had them check it and this is what it said-
P1136 - Manufacturer control fuel air metering
P1476 - Manufacturer control auxiliary emission control
This is what was just done
Removed and replaced throttle body valve unit and stage unit control unit and replaced barometric sensor
Replaced ignition module, throttle body, and baro sensor
Old Oct 10, 2008 | 02:20 PM
CCA4's Avatar
Take it back to the dealer and raise hell
Old Oct 10, 2008 | 04:15 PM
blkb5a4's Avatar
yeah i did that and they said it is from the computer saying it is running a little rich and but when they clamp the dv hose it stops so I had to get a new dv
Old Oct 10, 2008 | 04:39 PM
ghost6303's Avatar
which dv hose? theres 3 of them. also WHAT CAR IS THIS ON?
Old Oct 10, 2008 | 05:38 PM
blkb5a4's Avatar
it is the one that runs into the top of the DV its the one that you would hook a boost gauge up to. Its a 97 a4 1.8t
Old Oct 10, 2008 | 11:14 PM
ghost6303's Avatar
the way audi lets any old autozone scanner work on it is because they translate the VAG codes (5 digit number) into a generic OBDII P-codes. the P codes tell you very general information about the problem. the VAG codes gives you specific info about the problem.
is vag code:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
and P1476 - Manufacturer control auxiliary emission control
really means...
17878 - EVAP Emission Contr.LDP Circ Malfunction/Insufficient Vacuum
so Fuel Trim: Bank 1 (Add): System too Lean means theres not enough gas in relation to air in the engine (theres too much air getting in). (add) means the ECU is adding fuel to compensate. bank 1 just means which side of the engine, you have an inline 4 engine so you only have one bank.
and EVAP Emission Contr.LDP Circ Malfunction/Insufficient Vacuum says you are getting insufficient vacuum, so air is leaking into the engine. this would explain the lean situation. so you probably have a leak. maybe someone at the dealer forgot to connect a hose, something poped off on its own, or something is broken in your vacuum system.
fox3inbound
Aug 27, 2013 03:32 AM
Smyleysjoint
Apr 27, 2013 12:56 AM
brett83
Aug 12, 2009 07:32 PM
mattr7786
Jun 22, 2007 08:18 PM
maciunast
May 20, 2006 12:40 PM
