front hub bolt torq spec???help
Old Oct 11, 2008 | 08:36 PM
4GAZM's Avatar
Default front hub bolt torq spec???help
hi guys i took off my steering knuckel on the passinger side and had the new bearing installed and bolted all the ball joints up again and now i have to install the new hub bolt to the hub how tight do i make it or what are the steps i take to tighten it, i dont want to crush the bearing but i know that on my mini you make it tighter than S##T i know hubs are a little different than just niormal bearings on older cars but i just want to be safe here
thanks for any info !!!!!
Old Oct 11, 2008 | 10:13 PM
ryuuoh's Avatar
Those are single use bolts, not to be reused. The torque for the M14 is 115 Nm plus 180° turn, M16 is 190 Nm plus 180° turn.
Old Oct 12, 2008 | 10:30 AM
4GAZM's Avatar
what is that in ft lbs my torq wrench only goes in ft lbs also this is a 2001 a6 quattro is that the m16? i got the new bolt just want to get it write so when shes driving off the rd it dosent break
Old Oct 12, 2008 | 12:30 PM
ryuuoh's Avatar
My A6 came with an Allen head bolt, the replacement was an M16. 190 Nm is 140 Lb/ft. Use a long breaker bar with a short impact socket and a 2 inch 2 ft long pipe to get the extra 180 on the bolt.
dahaker
Sep 10, 2010 02:07 PM
mo_tt
Apr 7, 2009 09:44 AM
ottoaudi
Jan 18, 2008 07:38 PM
B5luver
Jan 2, 2008 11:23 PM
99a4avant
Aug 11, 2007 12:23 AM
