Crank bolt torque spec?
Old Aug 6, 2007 | 09:57 PM
99a4avant's Avatar
Default Crank bolt torque spec?
Does anyone have the correct ft-lb torque spec for the crank bolt ona '99 A4 2.8L 30V engine? I replaced the crank seal and want to be sure the bolt/sprocket is torqued correctly.
Thanks!
Old Aug 7, 2007 | 11:15 PM
acetrebo's Avatar
Default RE: Crank bolt torque spec?
What exactly do you need?
You caught me at home, and I have my haynes manual in hand.....
Old Aug 7, 2007 | 11:19 PM
acetrebo's Avatar
Crankshaft drive sproket bolt (with bolt oiled) (always use new bolt!)
step one...torque to 148 ft/lbs
step two...tighten an additional 180 degrees
Old Aug 7, 2007 | 11:25 PM
acetrebo's Avatar
crankshaft pulley bolts......18 ft/lbs
crankshaft rear oil seal housing bolts......84 INCH/lbs
Hope that covers it for you, if not let me know.
Old Aug 8, 2007 | 03:15 PM
acetrebo's Avatar
Avant80@2.6 you out there?
He needs this as well, and I am far away from my manual!
Thanks!
I saw the info for the crankshaft and pulley (thanks!), so I just wanted to verify the correct spec. for the camshaft bolt as well.
Old Aug 10, 2007 | 12:14 AM
acetrebo's Avatar
camshaft sproket bolt
sohc 52 ft/lbs
dohc 41 ft/lbs
Old Aug 10, 2007 | 12:41 AM
auditech79's Avatar
Un-grateful noob! Never even gave you a thank you.[sm=chairshot.gif]
Old Aug 10, 2007 | 03:57 AM
techbod's Avatar
he PMed me and I sent the data he required but Ill put it up for the others
[IMG]local://upfiles/12092/900E6340BF534F80828A6A9F10EE0FFF.jpg[/IMG]
Old Aug 10, 2007 | 04:02 AM
techbod's Avatar
hehe just noticed I didn't open the file for the spec[:-]
[IMG]local://upfiles/12092/DD3D15EFD0EB4917A9B88FC2140F9DFC.jpg[/IMG]
Old Aug 11, 2007 | 12:23 AM
acetrebo's Avatar
Its a thankless hobby sometimes......lol
Jstump
Jul 14, 2009 03:20 PM
chefro
May 5, 2009 12:34 AM
SSn
Feb 27, 2007 11:13 PM
00A41.8Quattro
Nov 23, 2006 08:47 PM
jonus079
Aug 21, 2006 04:16 PM
