help with Camshaft Position Sensor (G40) Open or Short to Plus
Old Jul 11, 2008 | 03:06 AM
beemerfanatic's Avatar
Default help with Camshaft Position Sensor (G40) Open or Short to Plus
hello! im from norway,and i had my car(a6 2.8,98mod) scanned with wag-com.
Control Module Part Number: 4D0 907 551 P
Component and/or Version: 2.8L V6/5V MOTR HS D02
Software Coding: 04102
Work Shop Code: WSC 02324
1 Fault Found:
17746 - Camshaft Position Sensor (G40) Open or Short to Plus
P1338 - 35-10 - - - Intermittent
i got a message that i can't se to find out of,and i have tryed to find somthing on the net but i am confused. is there someone that can help me?
my car have runned 266000km.not surewhat that's is in miles.
i have tested the sensores and i get arround 12 volt.
can it be somthing else that couses the problem?? timingbelt?camposition?
when i drive an put the pedal to the metal,the car starts to shake somehow at low register..[:@] i have replased the sensor at the airintake,the one that mesures the air..(i do not know the english word for it) it was not that one that causes the shake either.[&:]
the exaust have i leack by the flexpipe and there is a noise from the cat.maybe the the stuff inside is loose.
can that couse the problem?
i hope there is someone outthere ho can help me,or i'm going to sell the car!i'm fedd up with all the problems on it.[:@]
excuse my bad english!
best regards!
Old Jul 11, 2008 | 08:33 AM
NH_USA's Avatar
Default RE: help with Camshaft Position Sensor (G40) Open or Short to Plus
Try replacing the item that is bad The cam sensor
Here are linksshowing picts fora 95 A6
[IMG]http://i263.photobucket.com/albums/i...e/P1010195.jpg[/IMG]
[IMG]http://i263.photobucket.com/albums/i...e/P1010196.jpg[/IMG]
[IMG]http://i263.photobucket.com/albums/i...e/P1010199.jpg[/IMG]
Old Jul 11, 2008 | 02:30 PM
auditech79's Avatar
Check the slack on your timing belt, 75% of the time when you get any kind of cam position fault its because the timing belt jumped a tooth or isn't tensioned correctly. Another cause is not doing the timing belt job correctly.
Old Jul 12, 2008 | 07:14 AM
tnx!! i will try to see if i get the time to check it out tomorrow.
Old Jul 13, 2008 | 02:41 PM
hello!
i had a look at it to day. i removed the cover on the left side and i could twist the belt arround 90". therewas some slack on your timing belt so thatcan be the problem.strange...
the car have only run 23000kmafter it was changed last time..
Old Jul 13, 2008 | 02:47 PM
auditech79's Avatar
I would suspect crappy workmanship, take it back to the shop that did the timing belt. I would imaging they didn't replace the tensioners or didn't torque them correctly.
Old Jul 13, 2008 | 04:56 PM
it was done before i bought the car allmoust a year a go... i will fix it my self,so i know the job will be done right! mabye i can torque it right my self and se if it will do the job. if not i will buy a complete set and change it.
do you know what kind of sensor that is on the other side of the camshaft? i unfastened itand i saw oil on it. was a little tap in the middle..
Old Jul 15, 2008 | 10:24 PM
kimi's Avatar
im not sure what that sensor is for, it may be for the chain,but if i were you i will leave that in place first, and rule out what seem to be causing the prob now. i had a code p1340, afterdoing the timing job myself without the specific tools,went off timing,i got the tools did the job all over and p1338 puped up, i changed my cam sensor but have not checked again if the code is gone.if you have to do this job your self make sure you have the tools (cam lock bar and crank lock bolt)the former is crucial for an easier andjob well done, other wise you may encounter some difficulties
Old Jul 17, 2008 | 01:47 AM
tnx! i will try to remember that!
Old Aug 22, 2008 | 01:10 AM
Smile
ok,yesterday i was going to change the timeblt,but the problem was the tensioner and a loos bolt on the weel that tutches the tensioner(dont know the name). i changed the tensioner and tightened the bolt.
the tensioner was not changed at the timebelt change last time. ******* workchop!!
well.. the car runs great now. to bad that i spent all that money om tools and parts for nothing.. at least i got the parts for the 360000 km change :-)
i will scan the car again to day and see if the camsensor error is gone.
tnx again for all the help!!:-)
