Fuel pump
Old Jun 5, 2007 | 03:29 PM
kakarot's Avatar
Default Fuel pump
Looks like my fuel pump sized.
I checked the voltage to the pump when you turn the igniotion, and it looks like it sends 12.6V to it then turns off.
Then I cheked the resitence of the fuel pump, it gave me 0.6ohms, I thinks thats bad.
Then I cheked the fuel sender resistence and it was 75.5 Ohms.
so I guess I will need a fuel pump, Any good cheap place I can get it at?
Old Jun 5, 2007 | 03:36 PM
techbod's Avatar
Default RE: Fuel pump
breakers yard ? I assume its Bosch and external ( same as the Mercedes )
Old Jun 5, 2007 | 04:05 PM
kakarot's Avatar
I think its internal in the tank, couse there are 4 wires going in, 2 thin, 2 thick.
Should I gamble on an used pump? I dont know, its my first fuel pump failure.
Old Jun 6, 2007 | 11:08 AM
kakarot's Avatar
my pump meraculasly started to run, so now car still wont start, I checked the CEL, and it gave me 2113.
I actually rember people with that problem.
Camshaft potiion sensor.
Car actually managed to start ones, which is wierd.
So I have ether bad sensor or bad wiring. Or bad timing.
Old Jun 6, 2007 | 11:13 AM
techbod's Avatar
2113 is insecure cam shaft sensor/rotor, wiring, poor connection, fuse, distributor/cam shaft alignment, cam sensor
Old Jun 6, 2007 | 11:16 AM
techbod's Avatar
it could easily be timing is out so adjust the distributor to correct it ( if you can that is)?
Old Jun 6, 2007 | 12:39 PM
kakarot's Avatar
I dont think I can adjust the timing on mine, it just has to be perfectly alighned. I will go out soon and check the sensor, ground, power for it.
Old Jun 8, 2007 | 04:32 PM
InExile's Avatar
used fuel pump is bad .... i think there is abetter version made by pieburg or someting like that ... you can advance or delay the timing with hte help of a distributor
skihigh2299
Oct 11, 2015 05:54 PM
skihigh2299
Sep 25, 2015 12:09 AM
jsethwerner225
Nov 14, 2014 01:55 PM
DJmart
Aug 3, 2013 11:08 AM
Luisthehomie
Oct 1, 2012 05:24 PM
