93 90cs quattro sometimes it starts sometimes it does'nt
Old Dec 3, 2006 | 07:12 PM
tmarch's Avatar
Default 93 90cs quattro sometimes it starts sometimes it does'nt
I recently bought a 1993 90cs quattro 2.8L V6 5speed 115,000miles. I have never owned a german car before so this is all new to me. I have come close to running it out of gas a few times in the past month(I have become accustumed to having an idiot light to tell me it's low on fuel). Anyway starting has become erratic. The check engine light has been coming on and off since I've owned it but I don't know if it has anything to do with my problem. If it is going to start it will do so the first time you crank the motor and once started it runs fine until you shut it off. Then when you try to restart it will try to fire on the first revolution but then it's a lost cause if it does'nt fire right away it's not going to fire again until you walk away and try the next day. Get back in it the next day and it will always fire on the first crank but it will only start about 50% of the time. I thought maybe I have a fuel problem filter or pump due to running it low on gas. I just got it started for the first time in a week let it run for about an hour while I cleared the 2ft of snow out then I took it out for a little rally in the snow brought it back turned it off and restarted it twice and it started fine the third time it would'nt start. It's been 15 degrees out so I have'nt tried to diagnose it yet. Not sure where the fuel filter is? Does it have a fuel pump relay that could be erratic? Whats an easy way to see if it's getting any fuel? Is there a way to test the fuel pump? Maybe it's not a fuel issue maybe it's not getting spark. Anyway sorry for the long winded explination just woundering if this is something common and if anyone could lead me in the right direction.
thanks for your help
tmarch
Old Dec 3, 2006 | 07:20 PM
techbod's Avatar
Default RE: 93 90cs quattro sometimes it starts sometimes it doesnt
check for pin holes in the fuel lines this will cause the fuel pressure to drop hence the none starting, the pump will cycle for a couple of seconds then when its up to pressure it will stop should you hear it running longer then suspect a fuel leak, this is a first part of the check list because many things without fault codes is just a guess
Old Dec 3, 2006 | 09:53 PM
tmarch's Avatar
When I turn the key to on I can't hear the fuel pump in the rear. I do hear a click in the front 2-3 seconds after I turn it on. Could this be the relay or is the fuel pump in the front. it's hard to tell because of the chimes from the insterment panal. Also where can I find a good cheap service manual. I see cheap cd's on ebay for $10 are they worth it?
thanks
tmarch
Old Nov 12, 2018 | 10:54 PM
JJWNJ4's Avatar
From: Jersey Shore—not the MJersey Shore but NOT MTV VERSION
Regarding a good cheap service/repai manual. I bought the cheap online manuals but always seem to have issues with accessing pages or chapters. Not sure but I suspect it has to do with the manual and not my iMac or iPad. Same holds true for access to a online manual. Troublesome. I finally broke down and found a new, factory manual for $80. It is well worth the bucks. It has so much detailed info, pics and illustrations that it is actually heavy enough that holding it with one hand is no easy task. It’s high quality all the way. I on,y purchased on eBay last week. It was delivered the second day after purchase after 9 pm. And that was contrary to it taking 5 business days. As life would have it I have it I haven’t had a free moment to explore the manual well. But the 5-10 minutes I spent thumbing throug it impressed me. And I’m normally cynical about integrity and quality these days. So I recommend putting out the time and bucks for a manual, assuming there is a good one available for your year/model. I’d also try eBay before Amazon because those available on Amazon weremhigh priced across the board with some people asking more than $200 for a new manual. Good luck.
Russ Pederson
Nov 10, 2016 09:27 PM
SmokeyA6
Jun 14, 2012 11:35 PM
dave944
Apr 9, 2012 05:23 PM
Amaxx00
Nov 3, 2011 12:12 PM
mshall05
Jun 9, 2005 02:30 AM
