electrical help
Old May 7, 2008 | 11:02 AM
viyamate's Avatar
Default electrical help
does anybody know what can cause the fuel pump relay not to work( the relay its new).
OK if I open the relay and push the connector I hear the fuel pump work but I dont get spark I check the forum before and read that the sender some times go bad. does any body had this problem before I really need some help the car its sitting out side for 3 month with no luck.
ANY ADVISED WILL HELP THANK U ALL!!!!!!!!!
Old May 13, 2008 | 12:33 AM
TurboRhatt's Avatar
Default RE: electrical help
Have you replaced the Pump??? I have had many things go wrong like this, I had a relay go bad because the pump was drawing too much amperage, then I replaced the pump, and the relay worked fine (Until the pump went back out...I have also had a problem with moisture if the fuse pannel top is off or has been off then the pins in the box might be corroded..Check it out...
Old May 13, 2008 | 11:24 AM
viyamate's Avatar
THANKS FOR THE ADVISE!
YES THE PUMP ITS NEW I'M GONNA TRY THE PINS MAY BE THIS HELP!
gradmundh
Oct 20, 2014 02:39 PM
Figgy1682
Jul 21, 2008 07:20 PM
gg
Apr 29, 2008 10:59 PM
acetrebo
Nov 22, 2006 05:17 PM
