Help, 1988 Audi E-Brake problem
Old Mar 3, 2006 | 03:05 AM
highaltitude's Avatar
Default Help, 1988 Audi E-Brake problem
Hey everyone
Hope someone can give me some insight in to a problem I am coming up with. My driver side rear E brake cable was seized along with the calipers, so i replaced both I installed them and tightened up the line. Now when I try to engage the E-brake it clicks and stiffens up but the brakes don't come on. The cables are moving and so are the calipers just not enough, so I adjusted all the way and tried again but all that happened was that i could only move up 2 clicks and the damn thing still would put the brakes on, only minor rubbing, so i tried a spacer in front of the adjuster nut, and the same problem occured lots of tension not much brake action. So in general im really confused if anyone has an idea or has been through the same problem and has a solution it would be extremly appreciated
Thanks Dave
Old Mar 3, 2006 | 08:56 AM
techbod's Avatar
Default RE: Help, 1988 Audi E-Brake problem
http://www.eveshamsquash.co.uk/audi/parkingbrake.html
Old Mar 6, 2006 | 01:09 AM
0fframp's Avatar
The self adjuster sucks and doesn't work well. What I had to do was to turn the adjuster until the rotor wouldn't fit then turn the adjuster the opposite direction until the rotor fits snugly but not binding.
Old Mar 6, 2006 | 10:26 AM
kakarot's Avatar
well I had fun with my Ebrake this winter, did drifting 180 side driving, and that all
Old Mar 16, 2006 | 04:09 PM
Stellaluna's Avatar
I had the same problem with my 1986 4000S. Unfortunately, in my case, it was because it turned out the car didn't have functional rear brakes- both wheel cylinders were leaking fluid, and the inside of the drum was completely soaked with it. Have you checked the rear brakes?
n_allegro
Dec 5, 2010 10:54 PM
CycleTron
Sep 30, 2008 11:00 PM
neoaudiquattro
Sep 12, 2006 03:47 AM
mcozea
Jul 26, 2006 12:12 AM
Inferno
Mar 16, 2006 04:35 PM
