HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 12, 2007 | 02:47 PM
techbod's Avatar
Default RE: HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
this could be oil leaking through a gap in the exhaust and the heat would make the smoke so don't panic so much
Old Oct 12, 2007 | 02:50 PM
techbod's Avatar
if the car starts ok and no smoke ill put it on the above^^ because its heat related ( engine warm = oil will burn ) so I would be looking for a leak
Old Oct 12, 2007 | 02:53 PM
cool_kyle_3000's Avatar
But then why would the engine sound fine and then sound like a diesel engine when it smokes
Old Oct 12, 2007 | 03:00 PM
techbod's Avatar
the oil leak could be at the spark plugs because the cam cover could have blown a seal
Old Oct 12, 2007 | 03:05 PM
oh so who could i check that out. cause i needs to make it to the shop
Old Oct 12, 2007 | 03:15 PM
techbod's Avatar
its a simple DIY remove thespark plug leadsand see if the oil is built up over the spark plugs if yes the oil is leaking, cam cover gasketis easy to replace
Old Oct 12, 2007 | 03:18 PM
ok ill take out the spark plugs and look for oil on them. I hope that is what it is
Old Oct 12, 2007 | 03:31 PM
  #18
techbod's Avatar
remember its an oil build up pressure linked with engine heat
Old Oct 12, 2007 | 03:33 PM
  #19
all the gauges read out like the engine is 100%
Old Oct 12, 2007 | 03:35 PM
  #20
techbod's Avatar
its pressure related
